The current workflow with 3phase components enables to generate blind schedules based on a logic for a sensor.
I am trying to control vertical blinds (0°, 45°, 90°, 135°) based on the illuminance value (DPGs) for certain sensors. I used 4 BSDF files for the 4-states.
After running the simulation, I would like to calculate annual metrices with the illuminance values for each sensor for each blinding state. So I would to get: (x,y,z)
x = blinding angle (0°, 45°, 90°, 135°)
y = hour
z = sensor point (in my case on of the four)
Could someone help me by using the Python component to generate a certain “3D matrix”?
I red already this topic below from @OlivierDambron which gives me a bit more insight:
But I don’t know how to do it by myself. My Python skills are not so well, but I want definitely want to learn it. Could anyone help me or give me advice? I suspect that the script doesn’t have to be difficult, but at the moment it feels very difficult because I haven’t enough knowledge about Python.
I will be happy to help whenever I get a chance but in order for us to help you, we need you to get started writing some code and we can take it from there.
Currently the way Honeybee[+] is set-up, and I agree that it is not necessarily the best approach, one sensor controls all the window groups. You can however write your own code and come up with a different logic. If you see the code that calculates the logic based on the sensor you will see how to access the values for a single sensor. What you need to do is:
Apply your logic to each sensor and generate the schedule for the blind based on the values.
Merge them together in a Honeybee[+] format which is a tuple with values for all window groups in each time-step.
As you said it is totally possible. You just need to get started. Here is the honeybee[+] code that calculates blind states:
Thank you so much for the information. At the moment, I am trying to figure it out by myself, but the way I do it now is not very elegant.
I will try to explain my situation as good as possible:
The simulation case is an office room with one big window in the south façade. I placed four sensors in this office, which represents to occupants who both look in two directions. The shading system are vertical blinds. (see the image below)
I used the three phase method to do a daylight simulation. I would like to control the vertical blind system by evaluating the performance of alle possible shading states a every timestep and for every sensor and select the most apporopriate state. I will use a penalty function to rank for every timestep the ‘best’ shading state, so at the end I would like have one list with blind states for the whole year.
A very informative and interesting example is the article of A. Ganji Kheybari and S. Hoffman:
There are different challenges for me, but the first one is to generate the illuminance values for every timestep, for every hour and for every sensor. I tried to do this with a combination of Honeybee and Python. Maybe my file below makes my problem more clear, represents my struggles and shows my nog very elegant work:
The last days I struggled a lot to achieve what is represented in the document above. Tomorrow I will start to work on your advice with the honeybee[+]code that calculates blind states. Can I use this code in the GH_python component or is it easier to adapt an existing component, for example Honeybee[+] Dynamic Blinds Schedule?
Thank you so much in advance for your time and that you are willing to help me.
