Generate solid from points Grasshopper
Hi guys, I would really appreciate if you can help me finish my algorithm in Grasshopper. As you can see in the attached snapshots, I created some points starting from a particular geometry. Those points describe the geometry’s shape (faces and vertices). Based on this, I would create a solids or surfaces that follow these points. Do you think is that possible?
You can try Delaunay Mesh component to do this.
