Generating colored sky in HoneyBee
I read that in the last few years a -C option was added to gendaylit that produces colored skies. I was wondering if there is a way to implement that in Honeybee? Any thoughts?
https://www.radiance-online.org/learning/documentation/manual-pages/pdfs/gendaylit.pdf
Belal
Hi Belal,
Gendylit supports the -C option but this has not been ported to Honeybee yet. I think it should be fairly simple to add a hack to make it work. I will post an update later today or tomorrow.
Regards,
Sarith
(Edit from previous post: Apparently I was running an old version of Radiance on my laptop)
Try the modified “Honeybee_Generate Climate Based” component in the attached gh file. You should be able to make it work.
Standard sky output:
Colored sky output:
2020-03-28 15_24_31-Window
The input for user defined locus does not appear to be working with (at least the Windows version of) gendaylit. I need to figure out a bit more before updating this functionality to the source code. But you should be able to copy-paste that component into your project and make it work.
Sarith
cc: @mostapha (https://github.com/ladybug-tools/honeybee-legacy/issues/741)
Honeybee_Image-based_Daylight_Analysis.gh (511.2 KB)
Thanks Sarith, appreciate taking the time to add that option. Do you know how I can get the new gendaylit files that accept this option on windows?
Belal
Hi Belal, the version of Radiance that is available from NREL’s github repository will support this option.
