Dear all,
Thanks for your time.
I am new to HBPlus, and just start creating a simple box room to simulate sDA and ASE.
When I connected wall geometry to HBSurface, it has error coming out “1. Solution exception:‘module’ object has no attribute ‘isplus’”:
Then I tried to connected geometry to HBToRad then to HBSurface, it seems no error but the output of HBToRad is null:
Any suggestions would be appreciated!
Thank you for replying!
I did just like what you showed, but it doesn’t work.
error message: 1. Solution exception:‘module’ object has no attribute ‘isplus’
Hi @catsquito,
Like this it should work. If you want to name the sufaces you have to take into account that every surface has to have a unique name. With three surfaces three names. Without giving names to the surfaces Honeybee will do it for you.
Hi @Erikbeeren,
Thanks for your replying.
As I am new to HB[+] and haven’t worked on HB for a few years, I am wondering if I installed HB[+] and LB[+] correctly, or there is any conflict because of the HB and LB versions I am using.
I am currently using LB VER 0.0.67 (NOV_20_2018) and HB VER 0.0.64 (DEC_05_2018)
The HB[+] and LB[+] I have look like below:
HB[+] version is 0.0.04
If they are different version from yours, it would be great if you can let me know.
Any suggestions will be appreciated!
catsquito
Hi @catsquito,
This is a new subject. You need to create a new topic.
But to answer your question, I do not use HB[+] because energy simulation is not yet in there.
Hi @Erikbeeren
Thanks for the suggestion!
I will create a new post
