Geometry Import from Openstudio
I am trying to import an existing idf geometry file from Openstudio and everytime I look at the model in Rhino, the rooms are on-top of one another.
I tried importing a few idf files from the EPlus example directory and from DesignBuilder, both work much better and give geometry that matches the layout of thermal zones.
Is there anything I am missing in my model? or in how the import idf function works?
exported from OS 2.idf (677 KB)
Hi Neil,
Coordinates in OpenStudio are relative however coordinates in Honeybee have to be absolute coordinates. You’re using a fairly old version of the component (yes! The one on food4Rhino is fairly old). The newer version which you can find on github imports them correctly. I suggest you to update all your components with github.
Mostapha
