Hallo Dear @mostapha,
sorry if I disturb you.
I wanted to ask you, if has ever been taken in consideration to be able to edit the sensor grid of a geometry for the _DirectSunHours component, to overcome the problem of having a uniform grid and not to have the situation like the image.
The daylight analysis component, uses the _gentestpoints to create the sensor grid, but if the geometry is “badly” constructed, I have the same problem using the _gentestpoints.
In this case I solve the problem with the amazing component of AntonelloDiNunzio from this topic: Uniform grid for unclosed surfaces with hole, but I can’t used for the first option.
Greetings and best regard
