Getting native Radiance Commands from Ladybug Tools workflows (Luigi, Queenbee)
Hello Ladybug Tools community,
For a long time I have been working with Ladybug Tools now, but I’m new in this forum.
In a recent Radiance research project, I need to keep track on a low level on what is being excecuted in Radiance. Whereas in the Legacy versions everything was written directy to the Radiance path, now the execution is handled through queenbee/Luigi routines. I was working intensly in the LBT libraries, but I could not figure out how exactly Luigi gets the Radiance commands to be executed. I found the debug commands.bat files, but also here, no native Radiance commands are given. Is there a trick to make these Radiance exectutions visible (which I assume have to occur in some place). Something like: rtrace -h -ov -ab 1 -ap global.pm 50 -ap caustic.pm 50 scene.oct < samples.inp > illum.out (example from radsite)
I’m asking as we are trying to track and double check the final Radiance commands.
Thank you already for your help in advance!
Rafael
Hi @RafaelBartsch,
Thank you for posting your question on the forum. I also saw your email. Sorry about getting back to you so late.
You’re on the right track here. Once you find the honeybee-radiance commands you can find the native Radiance command in the relevant module here:
Most commands have a --dry-run option that will print out the exact Radiance command that will be executed under the hood. Here is an example:
Basically, try to run the same command that you find in the debug mode with --dry-run and you will see the Radiance command.
