Inn the ghpython script, the input I give is of rooms, but the output I get is faces… could anyone kindly please help me sort this out.
the python script I have used is
Hi @VidyaRamesh ,
In Honeybee, Room
is an iterable
object, so if you do:
for i in room:
# type(i) == Face
i
will be a Face
in that case.
If you wish to iterate over the list of Rooms that you input to the GHPython component, you need to change the GHPython node x
to a list
type input. So right click on x
and select list
from the dropdown menu.
all the best,
@edpmay
Thank You so much @edpmay ! Yeah I wanted to convert it to rooms, and once I changed it to list access, the error is gone and the script is working. Thankyou so much again!
