Hi all
I have three glare related questions
- Is it possible to pinpoint luminance values(for example the maximum value) to my image like this:
2. How can I set a minimum value to the legend? There is an input for the maximum value, but not for the minimum. The mask threshold doesn’t quite do what I want because I don’t want the surfaces with luminance values below the minimum value to be black.
3. The glare analysis component has an output for ‘image with task position’, but when I connect a task position and angle, I get an empty output. Why does this happen? (UPDATE: RUNNING THE UPDATE AGAIN AND REPLACING THE COMPONENT SOLVED THIS)
Thank you for your help
