Glare analysis example file
Are there any available example files of a glare analysis with honeybee?
Thanks in advance,
Ale
H
Here you go.
Attached also an empty rhino file that has only the saved views for your convenience.
You “just” need to manage with the results.
TestOneZone_Glare_Views.3dm (28.1 KB)
TestOneZone_Glare.gh (460 KB)
Thank you Abraham!
Hi Abraham,
I tried to use your example and didn’t change anything. However, I came across a runtime error as attached. Could you please offer help?
Carmen
The error that you see is a version incompatibility. Update all the components including Honeybee_Honeybee to the same version and it will work fine.
Dear Mostapha,
Yes. It works. Thanks for your advice.
Cheers,
Carmen
Hi - the links for the example files above are broken.
Could someone possibly post another example file for annual glare analysis?
Thank you!
Hi @grahamjlinn,
Attached the files. Though didn’t update them since the discussion.
-A.TestOneZone_Glare_Views.3dm (28.1 KB)
TestOneZone_Glare.gh (473.8 KB)
