we are three students working on our master thesis and we should make a glare analysis of a room, everything seems to work, except for the Glare Analysis Honeybee panel that keeps showing the same error.
The message that shows up is:
Failed to find size of the picture. It will be set to 800.
Solution exception:need more than 1 values to unpack
Which could be the problem?
I don’t know why i can’t attach any file…
It works fine on my machine. Most likely it is because that the path to weather file has several white spaces. Copy the weather file to a different folder with no white space and try again.
The error is happening at the HB_glareAnalysis component.
Can you say that the analysis is performed and you have the results files?
Looks like those are missing …
There is a slight chance that is a header issue. @erica.pie.ele ,which version of Radiance is installed on your machine? You can find your version by running rtrace -version on the command prompt.
