Hello all,
I am trying to perform a glare analysis using the UGR scale. I looked upon examples and could only find examples related to the DGP and DGI scale. Is there a way to run change/modify the results to match with the UGR scale?
Thanks in advance
Hi Muzafarm,
The Unified Glare Rating (UGR) is calculated by default in Honeybee; it can be found in readMe as shown in the figure below.
However, in the glare component only DGP and DGI is shown. To add UGR as an output of the glare component, you can simply add another parameter (zoom in and hit the + sign) called UGR. Open the component and write the code as shown on lines 339 and 344 in the figure below.
Hi @mikkel
Thank you for your quick response. Much appreciated
