Hi, I’m analyzing annual daylight and energy simulation at the same time so I made glass by window LBNL and export it as an Energy plus IDF file then import it to honeybee_import window IDF report then set it as an EPConstruction.
here is the question, i need same exact glass for RAD material input. how should I make this thing up?
If is there any other way to set glass similarly for both EPconstruction and RADmatrial, please help me.
Thank you- N.Z
You can simplify it into glass material (based on Tvis)
Or making it through these steps (Advanced users only!):
If you use 3-phase method you can use the BSDF xml file instead.
hi,
thank you for answering me, so I can use total Tvis calculated on Window LBNL then set it to the radiance glass material. is it right?
and what about the refractive index? what value should I set for it?
@nasrollah Refractive index can use the default value.
