hi, mingganyin
I have the same problem with shuta and I have tried your way, may I ask a question about how did you set the parameters of ‘_specularReflection’, ‘_diffuseTransmission’ and ‘_specularTransmission’?
The explanation of this component that I found on its home page is like this, which feels more like prescribed options:
‘_specularReflection: Reflected specularity; Matte = min 0, Uncoated Glass ~ .06, Satin = suggested max 0.07
_diffuseTransmission: Diffuse Transmission; Opaque = 0, Transparent = 1
_specularTransmission: Specular Transmission; Diffuse = 0, Clear = 1’
Can I use a customized parameter ? If possible, where can I set the transmittance of a glass?
appreciate your supporting!
