Glass partition as an interior shade
How can you make a glass partition inside an office space as an interior shade in Honey Bee Energy? I wanted the Honey Bee file
@Ghazaladib136445 you can define interior apertures and their constructions to take into account how transparent the glass is, as well as operability schedules just like exterior ones as long as the adjacencies are solved:
Thanks. But I meant defining the glass partition as an interior shade and giving it the glass material.
I did exactly the same thing myself. Only in ep-constru where I wanted to introduce it as glass and give it the glass material, I get an error message.
Does that mean you define the glass material only by the light transmission option?
this is a smart solution. we have defined a shade and only made a transparent material for only energy assessment. when we defined transmittance by 0.5 (fixed for whole year) means it can transfer half solar (material is supposed by default and you can change it by HB shade material). on other hand you can define a simple glass material (tv 0.5) for daylight simulation at the same time if you need.
Best
Ali Goharian
