hi all
could you please give me those equations that govern radiation analysis in ladybug? I gonna find mathematical documentation that governs radiation analysis in ladybug!
hi all
There is below methods in Duffie solar engineering book:
** clear sky…Hottel model
** cloudy sky …Erbs et all or Rabl or Liu & Jordan or …
** radiation on sloped surfaces: 1- isotropic 2. anisotrpic model
** anisotropic : 1. HDKR 2. Perez
could you please tell me, which above methods used in ladybug?
i need your answer for comparing my result with other authors.
@mostapha
like as you know, there is some mehods to gain radiation analysis on a surface,
coluld you please tell me ladybug use which method?
thanks in advance!
Park
Hi - I see now that the post I linked to on the Rhino Discourse was actually in a thread that was started by you.
There is a lot of information in that thread and these new posts don’t really seem to indicate that that was absorbed. At any rate, it would probably be better to continue in the original thread and ask specific follow-up questions there.
-wim
dear admin
unfortunately, i didnt get it.
i try to explain my problem:
Ladybug uses radiance’s gendaymtx to generate the sky. See gendaymtx documentation for more information.
Agreed! This is another one that you might want to check:
The link to the original discussion:
