Grabbing Hourly Temperature from Honeybee Energy Model Output
Hi, new to Honeybee energy modeling (have experience with TRNSYS).
My goal is to have an excel file with hourly operative interior temperature and relative humidity.
I have successfully run a shoebox energy model with the “Honeybee Model to OSM” component and then started to get where I want with “Honeybee Read Room Comfort Result” component visualizing hourly operative temp and RH. But not sure where to go from here to get the hourly temp and RH data in a spreadsheet so I can post process…can anyone suggest a method for doing this? Thank you !!
LB deconstruct data can be found in the Ladybug tab.
