I wanted two show two Therm simulations simultaniously in one window. When I run the simulations for the first time there is no problem, but when I change something in one simulation the coloured results of one simulation is projected over the other simulation. (see image below). Is it difficult to change the script so I can run and show two simulations at the same time?
If I understand your issue correctly, this is very easy to do. Just use a native Grasshopper “Move” component to move the coloredMesh, legend and title outputs from the second results component to be some distance away from the other results. Then turn the Preview off on the second “Read THERM Results” component.
Let me know if I’m misunderstanding the issue and, if so, could you provide a sample to recreate the error?
