Grasshopper AFN FanVent error index out of range
I’m working on an AFN (Airflow Network) model in Grasshopper using Honeybee, and I’m running into an issue with the FanVent component. When I connect my inputs, the component throws a “Solution exception: index was out of range. Must be non-negative and less than the size of the collection” error. I suspect it might be related to a data tree or list mismatch, but I’m not entirely sure where the issue is coming from. I’ve checked that the inputs (zones, fan parameters, schedules, etc.) are connected, but the error persists. Has anyone encountered this issue with FanVent in AFN, or can suggest what specific input mismatch or setup problem might be causing this? or is there any component that replaces Fanvent?
