How can I fix the following issues with DF Envimet Mange Workspace?
[Envimet Main Folder not found! Use DF Envimet Installation Directory to set installation folder of envimet.]
I use Grasshopper and Dragonfly for the first time. Are there any materials I can refer to?
Hi @yuha,
What is the full path of the directory of your Envimet software? E.g. C:\Envimet445
You can use “DF Envimet Installation Directory” to set it.
Best, Antonello
Hi, I have the same problem and I couldnt fixed it.I couldnt even use DF Envimet Installation Directory.how can I fix it. I couldnt find where is full path of envimet software.which om=ne should i search for?envimet plugin or envimet software
Same problem, any solution? Thanks in advance
Hello, have the same problem, did you solve it? I’m a little anxious, looking forward to your reply, thank you very much!
