Grasshopper Python script?
Hello all,
I just want to write a piece of script to post-process the output from the ladybug/honeybee components. However, I am not really sure how it works and why it behaves differently than the python I know. Anyhow, I just wrote a single line to print the input from the output of another component, and for some reason, the script ran 8767 times for an unknown reason. I mean, I only have one line of code, and why it ran more than once?
Could someone please help me to understand how to write this?
S
Hi @sz,
you need to select the right access type of inputs (right click on the ‘x’ and select among item, list, tree to see the difference) Take a look at this small example:
It run many times because you have declared access type ‘item’ but you are providing a list of values (8767) to x.
Regards,
Antonello
