Grasshopper Startup Warning after Pollination Install
I uninstalled ladybug from the Food4Rhino and then used the Pollination Installer. Everything seems to be fine and my old scripts work however I get this warning each time -
Priority: CategoryIcon
  Call PollinationLogger.LogHelper.OneTimeSetup(ILoggerFactory loggerFactory) to setup global loggerFactory first. (Parameter '_loggerFactory')
  ArgumentNullException
What version of the Rhino do you have? it’s likely the issue is from you have a very old version of Rhino.
I am on the latest release of rhino-
Version 8 SR33
(8.33.26188.13001, 2026-07-07)
@MingboPeng any updates on this?
@MingboPeng this is still happening. Any update on this? Is there some issue with my installation of pollination?
