Hi, I’m trying to get geometry from Grasshopper to IES using Grizzly Bear and gbXML.
My problem is that Rhino crashes when I try exporting more than 70-100 Volumes.
File attached with release HB 0.0.59, LB 0.0.62
I’ve tried the last releases except 0.60 since this problem appears.
http://www.grasshopper3d.com/group/ladybug/forum/topics/grizzlybear…
Another note is that IES don’t seem to be able to import constructions if the Id is more than 7 char. But I guess that’s an IES problem and not a Grizzly problem.
Does anyone have a solution to this? Or a better way of getting geometry with construction ID to IES.
Thanks
Oscar
Grizzly Export 125 boxes.gh (465 KB)
Hi Oscar,
Chris and I discussed the current issues with GB on Friday. We will be replacing this component by a new component that uses OpenStudio libraries. GB hasn’t been modified during the last two years and is not under active development and making periodic fixes will not be a good solution in the long run.It may take us a little bit of time but just wanted let you know that we’re working on this.
It may take us a little bit of time to add the new workflow but I just wanted let you know that we’re working on this.
Mostapha
Turns out the crash is a result of solving adjacency. If I don’t solve adjacencies, then I can export +500 zones with OpenStudio gbXML exporter. I need to have a closer look to find the issue. I attached the file if you want to try it yourself. It will take a couple of minutes to export the zones.
gbxmlExport.gh (526 KB)
I tested up to 1000 and it works fine again without adjacency. Will keep you posted.
