I think this is a fairly simple question but for some reason, the new annual daylight recipe for HB 1.2.0 is not giving me any outputs for both UDI_low and UDI_up.
I get results for DA, cDA, and UDI but for some reason UDI_low and up seem to be excluded from the simulation results.
Is this a bug or any tips to fix this issue?
Thanks
Thanks for letting us know, @Leite . This is a bug. Iâll push a fix to the development version of the plugin soon. In the meantime, you can always use the âHB Annual Daylight Metricsâ component to get the upper and lower UDI.
