Hi all
I was excited to try out the new gbXML loader, but I run into the following issue:
Am I doing something wrong? The opened file seems empty.
I am trying to load the Autodesk Advanced test model as gbXML from Revit.
Hi all
Hm. Do you have OpenStuido installed? It just occurred to me that I forgot to put a check for this inside the component. You need to have OpenStudio installed to use gbXML import and Export.
If you do have OpenStudio installed and itβs still not working, can you upload the gbXML file so that I can test?
I added a check for the OpenStudio installation into the development version of the component:
Let me know if installing OpenStudio fixes the issue for you.
