Thank you for considering sharing the sample file. You can upload it to Dropbox, Google Drive, or other similar services and share the link. That way someone should be able to help you.
Try to increase the ambient resolution in the Radiance parameters. You can use the “HB Ambient Resolution” component to calculate an appropriate value.
Hi @mikkel
I tried to increase it, I even tried with a value of 0 (if I well understood it is the most accurate ambient resolution) and I still have the problem.
I tried to run it with -aa 0.1 -ar 714 and the distribution of light seemed reasonable. I used the medium detail level in HB Radiance Parameter and added the values of aa and ar as additional parameters.
