Are you able to share your Grasshopper file with internalized geometry or just the HBJSON file of your model? You can find the latter in the project folder.
I tried running lb versioner multiple times earlier, but it did not seem to work until I ran it again while the toggle to component was set to true.
The script works well now.
@mikkel Hi,I have got a same problem in my research,but it counld be run at another computer.I have tried to update my core libraries by running [LB Versioner],but it didnt work. Is there any other way to solve it,thank you very much.
I have to see the exact error to help you. Can you share the log file or your script so I can try to recreate your issue? The log file is found at a location similar to this:
I pushed a fix. If you run LB Versioner again you should be able to get it.
However, I noticed that the Shades in your model causes the Radiance program oconv to run for a very long time*, and the resulting octree is larger than 5 GB, which is quite unusual. You should probably check your model and make sure there are no duplicates of Shades.
*It never finished inside Grasshopper so I had to test it manually by the honeybee-radiance CLI.
