HB Annual daylight simulation_problem rotating North direction
I’m trying to use my HBZones which i prepared for my energy simulation.
Everything works properly when the North is set to default. But when the rotation for North is connected, the following error appear:
  1. Solution exception:unsupported operand type(s) for +: ‘str’ and ‘NoneType’
I would appreciate any help.
Thank you in advance!
Faezeh
annual lighting_north problem.gh (692.1 KB)
I think that you have to set the quality in the RadParameters > 0
Hi, I have the same problem (str type). So if you can can fixed it I would like to know how.
Thank you so much.
