Hello!
While running the HB Annual Loads in my energy sim, I’m running into this problem.
‘‘1. Solution exception:Failed to write in.idf to file: [errno 112] There is not enough space on the disk.’’
I have recently ran into this problem, but I’ve always managed to solve it by adding a file path to the component.
For the HB Annual Load on the other hand, I am not aware of any such solutions.
So my question is: Is there a way one can adjust the file path for the energy simulation for HB Annual Load?
Thanks in advance!
