Hi everyone, I was following a tutorial online on how to create a basic energy model and run an annual loads sim and I can’t get it to work. I have gone back and looked at every step and I can’t figure out what went wrong. Everything works fine but the HB Annual Loads component. I am getting the following error: 1. Solution exception:‘DataTree[object]’ object has no attribute ‘float’
before I was also getting: 1. Solution exception: ** Fatal ** Errors occurred on processing input file. Pre
- I read online that it might be an incompatible version of Open studio but I checked and I am using the 1.8.0 version on Rhino 8
- I have tried using HB Annual Load in other models and it works just fine
Any help would be appreciated, thanks in advance!
(Link to the files) Unique Download Link | WeTransfer
