HB Annual Results to Data - Hourly results
I am trying to read hourly results by using “HB Annual Results to Data” component but the data output is not the hourly results per se… (unlike the “PeakValues” component)
Previously “Sensor Hourly Values” was used, but I understand that component is superseded now?
Hi @wxcchuck, you can deconstruct the LB data objects using “LB deconstruct data” to get the hourly numerical results.
The “Hourly Continuous Data Collection” is an object which contains the data and metadata (type, period, etc.).
Hi Charlie,
Thanks for the answer! Yes that makes sense. :slight_smile:
My question now is why does it still outputs all the HOYs of the year? Even though I have only plugged in selected HOYs (of one day) at the very beginning?
and also, is the “Sky Matrix” not needed anymore to run “AnnualIrradiance”? The older version (ver 0.0.06) had the “_skymtx” input…
Hi @wxcchuck,
I am looking looking for similar process, can I know where can I find the code?
it would be really help full for my research work.
