I’m experiencing the following severe errors when changing either the transmittance or reflectance values to something else than the default in the HB Blind Material 1.2.0 component.
** Severe ** WindowMaterial:Blind="BLINDMATERIAL_44D10FBF", Illegal value combination.
** ~~~ ** Slat Beam Visible Transmittance must equal Slat Diffuse Visible Transmittance
** Severe ** Errors found in creating the constructions defined with Construction:AirBoundary.
** Fatal ** GetSurfaceData: Errors discovered, program terminates.
The error states that the beam and diffuse transmittance must be the same, but they are the same according to the blind material:
Click to show material info
WindowMaterial:Blind,
BlindMaterial_e39e34dd, !- name
Horizontal, !- slat orientation
0.025, !- slat width {m}
0.01875, !- slat separation {m}
0.001, !- slat thickness {m}
45.0, !- slat angle {deg}
221.0, !- slat conductivity {W/m-K}
0.3, !- beam solar transmittance
0.5, !- beam solar reflectance front
0.5, !- beam solar reflectance back
0.3, !- diffuse solar transmittance
0.5, !- diffuse solar reflectance front
0.5, !- diffuse solar reflectance back
0.3, !- beam visible transmittance
0.5, !- beam visible reflectance front
0.5, !- beam visible reflectance back
0.3, !- diffuse visible transmittance
0.5, !- diffuse visible reflectance front
0.5, !- diffuse visible reflectance back
0.0, !- infrared transmittance
0.9, !- emissivity front
0.9, !- emissivity back
0.05, !- distance to glass {m}
0.5, !- top opening multiplier
0.5, !- bottom opening multiplier
0.5, !- left opening multiplier
0.5, !- right opening multiplier
0, !- minimum slat angle {deg}
180; !- maximum slat angle {deg}
Anyone know the solution to this problem?
Kind regards,
Marc
