Hello. I hope you are doing well. I have a problem with HB custom results. I am trying to get some output base on the energy plus outputs with HB custom output component however, it does not show me something defined. For example, I tried to get fan coil heating rate result but at the end it only showed electric fan energy consumption.
also, I am a beginner in HVAC design plane with ironbug, If there is a pdf guide book could you please share it with me?
I uploaded my gh file. I will be grateful if you check my file. thanks
https://drive.google.com/file/d/1V3i0Mt1KY_o5tptEisEpaa7uOzpy5OPr/view?usp=sharing
