I encountered the problem “1. Solution exception: The measure is invalid. Choice argument was found without any available choices.iteration over non-sequence of type NoneType” when using the HB load measure.
But when I run measure in Openstudio, there is no error.
If you are interested in this issue, thank you very much for your time.
The measure mentioned earlier:
AddDaylightSensors.zip (177.8 KB)
Same problem like:
ReplaceExteriorWindowConstruction.zip (230.2 KB)
I’m a beginner when it comes to using measures, and I’m encountering errors with not just this particular measure but several others as well. I’m not sure if there are any specific conditions or requirements for using these measures, and I’m also unsure where I should check the results after running them.
I would really appreciate any help or guidance you can provide. Thanks so much for your time!
