Hi @chris and/or other developers of the ladybug team,
First of all compliments for the new HB load measure component. This is really fantastic!
Just adding the directory path (step 1) and WHAM! (step 2). I was pleasantly suprised!
Then again, this is a simple Ideal Air Loads model where I’m not requesting a bunch of extra outputs.
Those result-parsing components are probably failing on your machine because there’s some E+ output that’s specific to the model you are running, which the reporting measure is overwriting. If you upload a minimal version of the Honeybee Model that’s needed to recreate the error, I can tell you exactly what is being overwritten and how to avoid it on your end.
