I’ve seen a few posts with a similar issue, but it was due to using the wrong units in Rhino. My units are set to meters but I’m still getting the error. Any help would be appreciated. File is attached. Thanks!
Thanks! I think you’re right. It’s running OS 3.4, and Python 3.7.9. I checked the compatibility matrix and it looks like I’ll need 3.10.10 to run OS 3.6.1. I’m still using Rhino 6. I’ve come to the conclusion that it’s time to upgrade to the new Rhino. But if there’s a workaround I’d be interested.
Have you tried running the one-click installer? it will install the required version of python and all of the bugs and their dependencies, this should get you the right version of python.
