I’m trying to run a simulation using the HB Model to OSM component, but it doesn’t work. I get this message “1. Solution exception:undefined method `name’ for nil:NilClass”. I attached the log file. Can someone help to understand what is wrong?
run.log (10.1 KB)
Thank @MarioAlves . Please upload a file with the bare minimum that is needed to recreate the error and I will investigate.
