I am getting error in Honeybee to openstudio.I attached the file. Can someone help to understand what is wrong? @chris
This was a bug in the LBT 1.6 release that has since been fixed in the development version. If you run the LB Versioner component or install Ladybug Tools by using the single-click Pollination Grasshopper installer you can get the component with the fix on your end.
