HB Opaque Material-Construction Issue
I am trying to add inputs for the specific heat in the HB Opaque Materials as the message says that the value shouldn’t be less than 100, referring to the first group. You can see that the HB Exterior Modifier Subset component is grey.
However, when I add any value to the specific heat, the HB Exterior Modifier Subset component turns red and it gives the following output warning “1. Solution exception:Expected Modifier for exterior_wall. Got <class ‘honeybee_energy.construction.opaque.OpaqueConstruction’>”.
I appreciate if someone would let me know how I should resolve this.
Thanks!
Hello @AlaaSaba, I cannot duplicate the issue on my machine
perhaps run the LB Versioner and see if an update will fix the issue for you?
Yeah, you’re right! I tried that and it is working fine.
Thank you.
