Hey @chris
I’m trying to understand what kind of input “Rooms” could be fed into the HB Peak Loads component.
If you saw my previous posts on the forum, I’ve been developing a workflow to analyze the peak heat gain in multiple zones on the Summer Design Day.
I’ve used the HB Model to OSM component with custom simulation params to get my results, but I was also trying to check out the HB Peak Loads component, since it gives the “Cooling Balance” result almost instantly, and I wanted to understand how this relates to the surface results I got from the Model to OSM component.
So I tried to plug in the Rooms input (after they’ve been assigned a construction set, room programs, loads, schedules, ideal air system - basically the same “Rooms” input that would go into the HB Model to OSM component) to the Peak Loads component, but if I do that, it throws a “FATAL error”, and it doesn’t run.
Whereas, if I just plug in the raw Rooms with just the apertures on them, it gives me a result.
I’m now trying to understand if the Peak Loads component is just designed for such kinds of VERY early studies to help understand the loads purely because of the geometry and the fenestrations.
Could use some help!
Harish.
