Hi everyone,
I was running HB PMV Comfort Map 1.7.0 without problems but since I updated to version 1.10.0, I got a repeated failure in CreateIrradianceContribMap.
The recipe failed with:
AttributeError: 'str' object has no attribute '_collection_type'
The log shows that most upstream tasks succeed, including spherical view factors, direct sky, direct sun, total sky, and ground reflected sky tasks. The failure happens specifically during Shortwave MRT Delta map calculation inside irradiancecontribmap.
I also tried these below attempts:
removed all dynamic aperture group components,
removed dynamic schedules of the aperture groups,
deleted the previous simulation output folders,
removed the HB Annual Daylight Metrics component,
but I still got the same error.
So this seems like the recipe is receiving a string where it expects a Ladybug/Honeybee DataCollection object. The failure appears to be inside the PMV comfort map workflow itself, not from leftover files in the simulation folder.
Has anyone seen this with HB PMV Comfort Map 1.10.0? Is this a known compatibility issue or a bug in the shortwave MRT / irradiance contribution step? Or is there a key modification in the component HB Model To OSM from version 1.7.2 to 1.10.0 that changes how the shortwave MRT is calculated? It also seems strange to me that the energy results, such as EUI and thermal comfort results from LB PMV Comfort are still being simulated without error, while it only happens with HB PMV Comfort Map.
Thanks so much in advance!
Hi @changf
I also received this error. Were you able to resolve it?
@chris do you know this problem’s reason?
Actually. the problem is the HB Window Construction Shade with the PMV Comfort Map recipe.
That is, the HB Window Construction Shade is fully valid in terms of the EnergyPlus definition, but the PMV Comfort Map recipe cannot process it in the Shortwave MRT calculation.
@Aliarch hello Dr. Goharian, thank you for useful share about this matter, respectfully do you have a net solution for this problem? I faced with same errors.
"Solution exception:
The recipe failed to run with the following error(s):
2026-09-23 21:50:35 ERROR: “CreateIrradianceContribMap” failed. See below for more information:
information:
AttributeError: ‘str’ object has no attribute ‘_collection_type’
2026-09-24 00:16:19 ERROR: “CreateIrradianceContribMap” failed. See below for more information:
2026-09-24 00:17:56 ERROR: “DirectSunGroup” failed. See below for more information:
rcontrib -I -V -aa 0.0 -ab 0 -ad 5000 -dc 1.0 -dj 0.0 -dr 0 -dt 0.0 -lw 2e-05 -y 14800 -M ./suns.mod scene.oct < grid.pts | rmtxop -ff - -c 0.265 0.670 0.065 > results.ill
2026-09-24 00:27:30 ERROR: “GroundReflectedSkyDiffGroup” failed. See below for more information:
rfluxmtx -I -aa 0.0 -ab 2 -ad 5000 -c 1 -dr 0 -faf -lw 2e-05 -y 14800 - “sky.dome” -i “”“scene.oct”“” < “grid.pts” | rmtxop -ff - “sky.mtx” -c 0.265 0.670 0.065 > “results.ill”
2026-09-24 00:28:13 ERROR: “TotalSkyDiffGroup” failed. See below for more information:
2026-09-24 00:29:58 ERROR: “GroundReflectedSkySpecGroup” failed. See below for more information:
2026-09-24 00:43:51 ERROR: “GroundReflectedSkyDiffGroup” failed. See below for more information:
2026-09-24 00:46:30 ERROR: “GroundReflectedSkySpecGroup” failed. See below for more information:
Execution Summary
Scheduled 264 tasks of which:
- 146 ran successfully:
- 2 CalculateSphericalViewFactors(…)
- 2 CalculateSphericalViewFactorsLoop(…)
- 2 ComputeSphericalViewFactors(…)
- 1 CopyGridInfo(…)
- 1 CopyRedistInfo(…)
- 25 failed:
- 11 CreateIrradianceContribMap(…)
- 2 DirectSkyGroup(…)
- 2 DirectSunGroup(…)
- 3 GroundReflectedSkyDiffGroup(…)
- 3 GroundReflectedSkySpecGroup(…)
- 93 were left pending, among these:
- 29 were missing external dependencies:
- 1 RunRadianceDynamicContribution(…)
- 7 RunRadianceDynamicContributionLoop(…)
- 7 RunRadianceWindowContrib(…)
- 14 RunRadianceWindowContribLoop(…)
- 19 had failed dependencies:
- 3 CreateIrradianceContribMap(…)
- 2 OutputMatrixMathGroup(…)
- 14 _RadianceContribEntryPoint_73edd45fOrchestrator(…)
- 16 had missing dependencies:
- 1 LetPmvComfortMapFly(…)
- 1 RestructureConditionIntensityResults(…)
- 1 RestructureConditionResults(…)
- 1 RestructureCspResults(…)
- 1 RestructureHspResults(…)
- 29 was not granted run permission by the scheduler:
This progress looks
because there were failed tasks"
