Your file has too many external dependencies and too many components for me to run it correctly on my end. Try running the simulation with the reoprt_out option and see if the error message in the report gives you any more information.
Alternatively, if you manage to make a minimal sample file that recreates the issue, let me know and I’ll try to reproduce the error on my end and push a fix.
I don’t know what is external dependency. The geometries are internalised, weather file is from ladybug map, construction and program are defined within the gh file. Could you please advise?
Anyway, I further simplified the script. The same error occurred. Link Building Fin Study_GD 7_forum.gh (331.6 KB)
Thank you, @XavierZhouLadybug . The simplified file is exactly what I was looking for and the log file in particular was extremely helpful. Thanks to your files, I found that there is a bug in honeybee that only affects cases where you have window U-factors that are equal to 3.4 W/m2-K. Changing the U-Factor to anything else (eg. 3.41 W/m2-K) will result in a successful simulation and you can use this right now to get a successful run of your comfort maps.
I also just pushed a fix for this case to the development version of the plugin:
It should be available with the LB Versioner in an hour or so and will also be in the next stable release.
Thank you, again, for finding and reporting this edge-case bug. I doubt I would have ever found this one myself.
