Hi @chris
For HB Properties by Guide Surface, is it possible to let the type_ input to have list List access?
What I have now is using the components 3 times to identify each types:
And if I do as a list for both _guide and type_:
Hi @chris
As you see, you can use List to input of “guide” .
If you set two type, the room will change to branch.
So you can retain this workflow.
