HB-Rad Direct Sun Results Visualisation
I am trying to use the HB-Rad Direct Sun hours component. The calculations run with no issue and the list of results seem correct, however I do not seem to be getting the results visualized in the viewport like the LB Direct sun component does.
Is this intentional? or am I missing a component that I am unaware of?
This is the sample Script I used for testing:
Direct Sun Hours.gh (44.7 KB)
I am looking to have it display results like this LB direct sun component example:
Hey @ssamryt,
If you place a LB Spatial Heatmap component and attach the “hours” result, the mesh from the LB generate point grid you can visualise the result.
You might also want to attach a Legend Parameters component to change the colour scheme to match the LB direct sun output
Thank you @charlie.brooker
