HB setpoints Error
so, i’m trying to create a constant schedule for setpoints, but when i put the type limit it gives an error saying 1. Solution exception:"Temperature
" was not found in the schedule type limits library.
how do i fix this? @chris some help would be much appreciated
@chris I cannot replicate the issue, here is the version I’m on though id be surprised if its the most up to date:
@prashhh do you know if your installation version is up to date? ( I don’t think mine is up to date but that may be a fix )
This error message says it all. There’s no schedule type limit named:
"Temperature
Just delete the line break after the Temperature input and it should work.
