I have recently found an issue while performing energy simulation through HB components. Although I found a technique to overcome the issue, I thought of informing you all about the problem.
Firstly, I have used HB Simulation Output component to avail EP surface results for simulation. The simulation could not even produce CSV file in the output folder.
I reviewed the IDF files generated in default folder and understood that the outputs defined by HB simulation output components is not being appended. But when I scripted through IDF editor or by additional strings input in HB run simulation component, its working fine!
First time itself, I have ran an update and then simulated. Today, I have ran an update again and still the LadyBug and HoneyBee components show the version as 0.68 and 0.65 respectively.
The test simulation has been ran and still error exists with simulation output component (May be only at my end).
