In ‘old’ HB ‘Annual result 1’ had annual profile output that could be used to update lightning schedules for E+ calculation. I do not see any lightswitch-related components but I was wondering if there is a workaround and something similar could be done with HB+?
Hi @Wujo, It is possible. See this: Parametric Daylight and Energy Simulation with HB[+]
Once you have the output values you can generate your schedule inside Grasshopper and create a csv schedule to connect to EnergyPlus simulation. The sample file for 3 phase covers most of this workflow.
