I am currently carrying out several analyses regarding the energy balance of a control room with different kind of shading systems, with the support of HB and LB.
I have modelled the window of the room layer by layer and added a blind or shade material to define my shading element (either interior, in between, and exterior).
I want to check the shgc, tsol, and tvis of the entire build-up (i.e. Glazing + Shading) but when I try to deconstruct the “Window Construction Shade” these parameters are provided for the “UNSHADED construction”, thus ignoring the blind/shade material.
Is there a way to visualize/extract/obtain these data for the entire build-up?
Thank you in advance!
