I’m attempting to create HDR and falsecolor images from .tif files and was able to successfully get this working with the base files located on my local hard drive. I tried to process images on a network drive and started having troubles. Is this a known error? Anything that can be done to run images located somewhere other than my desktop?
See attached images of the grasshopper file error and the batch file error. The only thing I need to change to get it to work properly is the file location.
Brett
