I want to set the Heat Balance Algorithm to Conduction Finite Difference in Ladybug 1.2.0 HB energy model. The default is Conduction Transfer Function. The only way I thought I could do it was through add_string_. However, since the default is set by the HB Energy component, it gives an error for assigning two HeatBalanceAlgorithm inputs. I can edit the IDF file in either text or the EnergyPlus environment. But I was looking for a way to be able to do it in Ladybug/Grasshopper environment.
Thanks
Hi @Habib ,
Youâre right that this isnât exposed in Honeybee and trying to specify this with additional strings will result in duplicated objects.
For now, the only way that you can change this is to either manually edit the IDF (and then use the âHB Rerun IDFâ to run the IDF through EnergyPlus) or you could write an OpenStudio Measure to change this attribute of the OSM (using the âHB Load Measureâ component to load it and apply it to the measure_ input of the simulation). The latter will be much more automated and reusable but it understandably has more of a learning curve given that youâll have to write a little Ruby.
Thanks, Chris, for the quick response. What I do for now is, as you mentioned, editing the IDF and then running it through either HB or EnergyPlus. Although itâs not that convenient, it takes less time than digging into writing a piece of code.
Hello chris I think this can be solved by a simple python battery, I replaced the Solar disturition parameter by this battery.
import os
Input variables
idf_file_path = x
old_content = y
new_content = z
Open the IDF file and read its contents
with open(idf_file_path, ârâ) as f:
file_content = f.read()
Replace the specified content with the replacement content
new_file_content = file_content.replace(old_content, new_content)
Get the file name and directory of the input IDF file
idf_file_dir, idf_file_name = os.path.split(idf_file_path)
Generate the output file path by appending â_updatedâ to the file name
output_file_path = os.path.join(idf_file_dir, idf_file_name.split(â.â)[0] + â_updated.idfâ)
Save the updated file contents
with open(output_file_path, âwâ) as f:
f.write(new_file_content)
Output the path to the updated IDF file
a = output_file_path
Sorry I forgot to respond and say that youâre solution is also a usable one, @xiaoyuling , albeit a slightly riskier one given that the IDF schema has been known to change between versions of EnergyPlus. But it will definitely get the job done.
In this application of Honeybee, I use IDF editor to modify the IDF file(Such as Heat Balance Algorithm ) automatically created by Honeybee, and then run it again with RUN IDF. If I modify a parameter in Honeybee later(Such as material thickness), and then click Run the âHB Model to OSMâ model in Grasshopper, will my original file be overwritten again(If that happens, modifying the algorithm wonât work)?
The new file will overwrite
